hi,
i have downloaded the latest version off sdk2015 and had copied the entire folder to c:/user/username/appdata/roaming/autodesk/revit/addins/2015....but,perhaps i still cannot see them under the addins tab, after launching revit.
kindly resolve this issue.
thanks
atul r. suri
UNsure if this is still an issue for you. You should first get the latest SDK and install the MSI.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2484975
This seems to need an actual install, not just a copy/paste.
Thank you for taking part in our community!
