Below is a copy of the error string (which I've divided at each line to aid in reading):
An error occurred during the installation of assembly
'FARO.LS,version="1.1.501.0",type="win32",
processorArchitecture="amd64",
publicKeyToken="1d23f5635ba800ab"'.
Please refer to Help and Support for more information.
I've followed all install instructions and removal and re-install directions in case prior install attempts left anything behind. I've turned off the UAC and disabled Symantec Endpoint Protection and tried again.
FYI: The error says "type=win32," but I'm running Win 7 64 bit.
Any help is greatly appreciated!
Solved by jessica.t. Go to Solution.
Hi, Welcome to Autodesk Community!
Please check if this solution can help you to resolve the issue.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
I have the same problem, and I have tried all the suggested solutions on different pages. Still cant get the Autocad installed on my computer.
Can you please help me with this? Very frustrating, I can not even choose not to install Faro as a part of AutoCAD installation.
Hi @Anonymous ,
Could you please try removing all Microsoft Visual C++ from your control panel under Programs and Features?
Once removed and before starting your re-installation, please take the following steps:
- You have administrator rights to the machine
- Disable your firewall or antivirus software
- Your Windows Temp folder isn't full
- One the Windows Start menu, enter %TEMP% in the "search programs and files" edit field
- In the Temp folder press CTRL+A to select all the files and folders contained in the Temp directory and delete them.
If the issue persists, please respond to this post with a copy of your installation log. Or please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. Thank you!
Hi Jessica,
I followed all your instructions, deleted all the Microsoft Visual C++, deleted the temp files, have admin rights, and turned off my Mcafee anti virus, but no success. I had the follwing errors and also attached the log files. I appreciate your help in rectifying this issue. This is probably my 10th attempt installing AutoCAD on my laptop.
Hi @Anonymous,
Will you try this Autodesk Solution and let me know if it helps resolve the issue? Thank you!
I am also getting the same error with the faro thing.
I disabled the antivirus, cleared the temp files and deleted the cpp programs. I also have administrator rights.
Attached are the log files.
