First off, I am appalled at the lack of service from Autodesk. This is how it works, I bought your product, I should be able to download your product immediately, but waiting over 24 hours? And then to have it give me errors during install? Then to top it all off It supposedly comes with advanced support, but can't find a phone number or chat room to save my life. After 1/2 an hour I finally find a phone number, and I swear they purposefully kept me on hold long enough for their shift to end and hung up on me. No chat service available and stuck with the community? I bought a product, it is not installing or downloading correctly. Please help!
Solved by Mark.Lancaster. Go to Solution.
Welcome to the community
I understand your frustration but this is a user forum and although Autodesk does monitor these forums, it doesn't mean they will actually see your posting/issue/frustration.
If you have problems your best response is to come here first. Granted you have adv support and stuff but users like @TravisNave, @Darin.Green, others, and myself can sometimes give you a faster response if your struggling or waiting for Autodesk. Maybe we would end up telling you to go to Autodesk but that way you know your on the right track.
If you were trying to install your product through your Autodesk Account that is most likely causing the issue.
Instead download and install per
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Update: If you do have adv support all that information is in your Autodesk Account
Mark Lancaster
& Autodesk Services MarketPlace Provider
Mark,
Wanted to say thank you for taking the time to answer this. I've been swamped since I finally go the download to work, but do appreciate the help.
Thanks!
