Installation & Licensing
Error en la instalacion de Revit 2014
5 REPLIES 5
391 Views, 5 Replies
Hola:
He tratado de instalar el REVIT 2014 varias veces y al concluir el proceso me indica que uno o varios problemas han ocurrido y que no se ha instaldo de forma correcta el REVIT 2014. De tal modo que a pesar de aparecer elelmentos en la carpeta no puedo ejecutar ninguno para comenzar a usarlo.
Adjunto una nota de texto en el que aparecen, entiendo, los errores por los cuales no se ha instalado el Revit 2014.
Gracias, espero sus respuestas.
Atentamente,
Javier
5 REPLIES 5
ukdxb012
Turn off the windows UAC (user account control), restart the machine and run the installer by right clicking it and run as administrator.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
in reply to: ukdxb012
this is my problem too. when i inestall it when it extracting it take an erorr message that says :: some are your files are corrupt. then it stops working. how can i repaire them??
dembkod
kavehslt
Hello. You can run a reinstall through the Control Panel. If this fails, I would downlado a clean copy of the Program and use that download.
Thank you for taking part in our community!
David Dembkoski
in reply to: dembkod
thank u dear
I try everything, but when the install process takes the process 6 appear a window that says "prearing revit content" and the process does not continue anymore.
Excuse me about my english.
Administrator Productivity
