Is it possible to downgrade? I would hope so as the computers at my school uses Maya 2016 but I have Maya 2018, I'm also wondering if i make something in 2018 and transfer it to 2016 will it end up not being compatible.
< Edited Content for better support. >
Solved by natasha.l. Go to Solution.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @Anonymous,
Thank you for posting. I provided some information below that will help you make a decision & learn more about your options.
Maya & Backwards Compatibility
It depends on the features & file format used but Maya is backward compatible, please review Maya Legacy File Compatibility.
Although your school is teaching a later version it should be fine to use a newer version the tools & features do not greatly differ from 2016 to 2018 & the Maya 2018 has applied updates & fixes so it could benefit you to have a newer version. Just as long as you save your files properly they will open in both versions & try to stay away from using special features from 2018 that will not open in 2016.
I will reach out to @sean.heasley, in case you have some more Maya specific questions.
Educational Software versions
Educational software includes the current version and 3 versions back & is offered for a term of 3 years. If you have not previously used a version that expired after the 3-year term, then Maya 2016 should still be available to you in your Education Community account & available for download (steps #3-4).
Let us know if you have any more questions.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
