.NET Framework 4.7 caused some Autodesk applications to crash:
Microsoft has published an early access .NET Framework 4.7.1:
Has it been tested by Autodesk? Does it fix the crashes?
Do not install any beta or pre release Microsoft regarding
Autodesk products. If Autodesk is testing they will make a formal announcement when they are finish testing.
Mark Lancaster
& Autodesk Services MarketPlace Provider
The trouble with current version of Windows 10 creators build is that .net 4.7 is built into the operating system so as far as i know cannot be uninstalled. This means that i cannot install IDS 2018 at all! I have been told that it is a microsoft issue by Autodesk which i firmly believe is a copout. When i get my laptop back i will be creating a system restore point, installing .net 4.7.1 and testing to see if i can install the 2018 products. This was a suggestion by Autodesk as well by the way. i see no harm in trying - at worst it isnt going to work. In my opinion Autodesk need to fix this issue with urgency.
