Installation & Licensing
Cant install INV2011 Content Centre Libraries
4 REPLIES 4
1313 Views, 4 Replies
I've had a lot of issues with our previous setup of Inventor2011.  we we using the content centre on the Vault server.  This seems very slow and would crash a lot as well as the frame generator being unusable.
I've since changed to using the content centre located on my C: drive.  This has improved the Frame generator issues and also accessing the content centre.  My issue is I have no content centre libraries on my local machine.  I've tried to install them from the Inventor 2011 install files but it keeps failing giving the attached log with a fatal error.
Can anybody help with installing the content centre to my local machine?  thanks
Guy
4 REPLIES 4
huliang2008
Did you install DC from Inventor suite DVD? or you download EF package from network.
please install DC via launching setup.exe and select DC to install.
Kevin Hu
SQA Eng
ACRD MFG
in reply to: huliang2008
I installed it via the downloaded files.  I ran setup and selected the content center files.  It still fails.
could it because I have a windows login to access my machine which causes the failure.  i've read this causes a lot of probelms with this software.
not impressed at all with this release.
huliang2008
please check if there is the file 'My Library.idz' under your source file folder:
C:\Documents and Settings\a468510\Desktop\Inventor 2011\DClibrary\Application Data\Autodesk\Inventor 2011\Content Center\Libraries\My Library.idz
if not, please download the attached file, unzip it and copy it into that folder and try to install again.
if that still doesn't work for you, please check if your source file is complete.
Kevin Hu
SQA Eng
ACRD MFG
I don't have anything else further under this stage of the file structure.
This is what is in that folder.
(see attached).
Should I redownload the Inventor files?
Administrator Productivity
