We recently purchased 2 networked licenses of Building Design Suite Premium 2014. My IT person mistakenly downloaded and installed the AutoCAD Design Suite Premium instead of the Building Design Suite Premium. The software activated and operates correctly, but I am missing the additional programs fromteh Building Design package. The only program that I need immedately is Revit so I downloaded the standalone version as a trial and after installing it I tried to activate it, but it will not accept my serial number.
Do I have to install the entire Design Suite Premium package to get a version of Revit that can be activated?
If so, do I have to uninstall the currently installed programs that are part of the AutoCAD Design Suite Premium package or can they remain?
Solved by DarrenP. Go to Solution.
since its a network license you should be fine the license file takes care of the licenses
the revit install needs to be installed as a network not as a trial
DarrenP
the only program you won't be able to use is Mudbox since this product is not in the Building Design Suite
DarrenP
nope it requires a uninstall/reinstall
DarrenP
