Installation & Licensing
batch plot fails in FlexLm situation
4 REPLIES 4
261 Views, 4 Replies
I'm upgrading a 5 user setup from Arch Desktop 2.0 to Arch Desktop 3.3,
using the FlexLm manager. When I try to run the batch plot utility from a
workstation, I get the message "Error Loading AutoCad for Batch Plot". When
this used to happen on Arch Desktop 2.0, I set the ACADSERVER environment
variable to point to the license server and that fixed the problem. Of
couse now the license technology is completely different, so does anyone
have a way around this problem? Thanks,
Mark
4 REPLIES 4
if the ACADSERVER helped in 2.0, try using the FlexLM variable called
LM_LICENSE_FILE=@server1
where server1 is the hostname of the FlexLM server. This overrides the
LICPATH.LIC -file that 2002 uses to find the server.
HTH
Petri Ahava
CAD-Quality Finland
"Mark Nienberg" wrote in message
news:F6F6D48FF52A2325C56BF247897BBC53@in.WebX.maYIadrTaRb...
When
> Mark
If Petri's advice doesn't work try launching autocad first and then
running the batch plot thingy.
jason martin
frankfurt-short-bruza
"Petri Ahava" wrote in message
news:2313824CF8EB5F1BE408086FC2416DC6@in.WebX.maYIadrTaRb...
> Hi,
> HTH
> Petri Ahava
> CAD-Quality Finland
> When
> > Mark
Thanks for the suggestion, but no luck. I tried various combinations of TCP
and UDP also without any difference. I can run Arch Desktop 3.3 fine, but
can't get the Batch Plot Utility to open AutoCad. Does anyone have this
working or do most people not use the Batch Plotting?
> Hi,
> HTH
> Petri Ahava
> CAD-Quality Finland
a
> When
environment
> > Mark
Batch Plot Utility opens a separate session of AutoCad if one is already
open, so it doesn't help to open AutoCad first. I tried it though, just for
completeness! No luck.
"jason martin" wrote in message
news:24978D616E62E37B7AB7ABAD7680FD2E@in.WebX.maYIadrTaRb...
first and then
> jason martin
> > Hi,
> > HTH
> > Petri Ahava
> > CAD-Quality Finland
3.3,
from a
> > When
environment
Of
anyone
> > > Mark
Administrator Productivity
