Greg -
If your adt3 cd does not say service pack 1 on it, you need a new CD. Contact your dealer
immediately. If your dealer tells you to download SP1 from autodesk's site, tell them that
they are (insert favorite derogatory term here), because the SP download does not include
the correct licensing files.
You will need to uninstall the client deployment that you have installed. You will need
to delete the deployment that you have created and create a new one from the SP1 CD, and
then re-install to the client. You do not need to re-install the adlm and you do not need
to get a new auth code.
hth
jason martin
frankfurt-short-bruza
"juslookin" wrote in message
news:FBED3986E84C7D6FD1B0B4DB582C7A08@in.WebX.maYIadrTaRb...
> We have decide to take the plunge into network licensing.
> I used an ADT3 disk to install ADLM and client deployment. Installed ADT3
> to the workstation but it won't run. Error - No licenses are currently
> available.
> Checked ADLM and it says I have 12 available (166 feature code).
> So I search autodesk support and find a document that says the origional
> version of the ADT3 Cd has a problem with the licensing feature and I need a
> new CD with service pack 1.
> Can someone shed some light on this?
> Will I need a new authorization code, after I get the new CD from Autodesk?
> Greg
