Installation & Licensing
Autodesk Maya 2014 installer says it is installed
7 REPLIES 7
Message 1 of 8
3272 Views, 7 Replies
I have Autodesk Maya 2013 64bit installed on my machine and I uninstalled it and tried Maya 2014. I have never installed 2014 before but when I installed it, the installer only installed BackBurner, MatchMover, and the like and says that Maya 2014 is installed even though it is not. I cannot find Maya 2014 on my registry so I come here to ask help if what registry key/s should I edit/delete. tnx
7 REPLIES 7
Message 2 of 8
david.lau
Use Microsoft Fix it to uinstall the program.  Basically, if the system thinks the software is already installed, Fix It will 'fix it".
http://upandready.typepad.com/up_and_ready/2012/06/windows-the-basics-of-using-microsoft-fix-it.html
David Lau
Message 3 of 8
in reply to: david.lau
Hi David.Lau
Thanks for the link but I kinda have a problem. My Operating System(Windows 8.1 64bit) is not yet supported. But thanks! I will wait for my system to be supported 😃
Message 4 of 8
dembkod
kfroldan,
Hello. You may be able to get past this phenomenon by deleting a specific reg key for Maya. If you delete this:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\D5CB8AF74EC73F24E8EA23FDB5BA357A
It may let the installer install over the remnants of the old install.
Thank you for taking part in our community!
David Dembkoski
Message 5 of 8
in reply to: dembkod
THANKS!!! That did the trick. Thanks for the help Autodesk Product Support 🙂
Message 6 of 8
Where would I find that file to Delete? I imputted it in the Command & Search Bar on Libraries, Nothing, Windows 7 64. Program was orriginally on one of my secondary SSDs
Message 7 of 8
ukdxb012
You will find the key in the windows registry via regedit.exe
Type Regedit into the search in Windows and you should find the program.
My i also suggest that you create a need community post regarding this if my recommendation does not help you.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 8 of 8
Hi, I am using Autodesk Maya 2016. Can u help me out, which registery key, do i have to delete. I have tried Microsoft fix it and also deleted all folders associated name of Autodesk or Maya but nothing worked. I would be grateful if you help, which reg. key do I have to delete
Thank you
Administrator Productivity
