Installation & Licensing
AutoCAD Raster Design 2014 - Error 1606 with Roaming profiles
1 REPLY 1
563 Views, 1 Reply
Have installed AutoCAD 2014 on vmware view master image with local profile.  All works properly.  desktops deployed from master image using persona management (roaming profiles) generate the error in the screen grab when run.  Bascially AutoCAD Raster Design 2014 appears to be inserting "\\" between enu and support, causing the path not to be found.
How can I resolve this isssue?
Thanks!
1 REPLY 1
We have the exact same error using roaming profiles. The folders are all in the users roaming profile, they have full permission, yet we get the same error as you 1606.
Administrator Productivity
