Installation fails when it gets to Content Service with installer error code 2738. I previously had a successful installation on this machine where the software would run but I couldn't access the content libraries. The dialogue box would come up with nothing there. I tried uninstalling everything, including folders and registry keys, but now re-install doesn't work. I've attached the install log. Any help would be greatly appreciated!
Did you run CC cleaner? That is happening because you had the version previously installed.
I also see that you dont have admin rights on your system, at least reading the log.
Can you fix that?
Hello Christine,
I believe Frederico is spot on in that you may have remnants of the previous install preventing a new one from completing. There are a couple other "non-supported" clean uninstall processes listed here, along with our "supported" method.
