AutoCAD 2015 Failed Installation
Message 1 of 90
Hello, I am getting this error in windows 8.1 ".net 4.5 is not installed . autocad 2015 cannot be installled without this component. see your system administrator for more information" Though it installed and enabled. Is there problem with autocad or my Windows 8.1.
Replies (89)
Message 2 of 90
asburyj
the .net framework should already be on you system on windows 8.1 unless it was somehow disabled. It may be you have installed the preview version of .net framework 4.6 which the installer wouldn't recognize. Can you check your list of installed programs with the programs and features control panel and see if you have .net 4.6 installed instead?
Jeffry Asbury
Message 3 of 90
I have checked the Installed Programs there is no Installed preview version of .net framework 4.6. Though I installed Autodek 3ds max 2015 It worked perfectly.
Message 4 of 90
perfectly.
Message 5 of 90
asburyj
Can you try running the installer linked below and let me know the results?
http://www.microsoft.com/en-us/download/details.aspx?id=42643
Jeffry Asbury
Message 6 of 90
I am sending the screenshot of link tested and My .net framework features
are enabled from "windows features on or off" too.​
Message 7 of 90
Message 8 of 90
asburyj
Seems like you should be all set. I am not sure why the installer is not detecting it. What install method are you using? Is this a downloaded installer or a install media?
Jeffry Asbury
Message 9 of 90
It's a downloaded installer.
Message 10 of 90
asburyj
if you downloaded a full installer take a look in the folder for a file called setup.ini and post it here. I'll edit the file for you to remove the check for .net framework and upload the modified file so you can potentially work around the problem.
Jeffry Asbury
Message 11 of 90
Here's the link to setup.ini file uploaded on google drive
https://drive.google.com/file/d/0B3d4sqN08nyUbHBuOVdJWGVnclE/view?usp=sharing
Message 12 of 90
Message 13 of 90
jeffryasbury1
Attached is a zip with the ini file modified to not check for .net framework 4 or 4.5. Assuming your .net install is actually present, as it seems to be, you shouldn't have any problems with this workaround. Just extract the setup.ini from the zip into the installer folder and replace the existing one that is already there. After that just launch the installer as normal.
Message 14 of 90
I did as you said but the installation failed again with same error. I am attaching the 'log file' with this this reply.
Message 15 of 90
TravisNave
Install	Autodesk® AutoCAD® 2015	Failed	Installation aborted, Result=1603
 AutoCAD simply did not install.  It is not failing on a prerequisite or an add-on.
Do you have any other vertical flavors of AutoCAD installed from another suite or trial?
Are you installing with local admin rights, UAC off, and anti-virus disabled?
I recommend installing as a custom install and making sure that you are not adding any service packs to the installation when installing.  You might also need to install as another admin user, or change the location of your %TEMP% and %TMP% folders.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 16 of 90
asburyj
Can you attach the details install log for AutoCAD 2015? The log will be generated in the TEMP directory which can be accessed by typing '%temp%' in the START > RUN. It  have a naming convention of Autodesk AutoCAD 2015 Install.log . This detailed log should pinpoint the exact failing function of the install. The setup.log you already provided just let's us know it failed on the AutoCAD portion of the install.
Jeffry Asbury
Message 17 of 90
Here is the Autocad 2015 installation log.
Message 18 of 90
asburyj
Well there's not much additional information here. The installer is not able to find or use part of your .net framework to perform an installation
Action ended 22:03:12: SetAdlmBothLicenseType. Return value 1.
Action start 22:03:12: LaunchConditions.
MSI (s) (0C:14) [22:03:23:981]: Product: AutoCAD 2015 - English -- .NET 4.5 is not installed. AutoCAD 2015 cannot be installed without this component. See your system administrator for more information."
My guess is thier is either a permission issue of some kind or your .net framework install might be corrupt? If you are using a administrator account to install I would suggest repairing your .net framework installation.
http://blogs.msdn.com/b/dotnet/archive/2014/04/28/introducing-the-microsoft-net-framework-repair-too...
Jeffry Asbury
Message 19 of 90
Yes I tried installing it with local admin rights , UAC off and anti virus disabled, but Installation fails at the same error.
Message 20 of 90
Repair was successfully completed but the same error pops up again.
