I am the proud owner of an Autocad 2007 program, purchased right about 2007 and with all of the proper documents, but am getting compatibility resistance when post-download to a PC with Windows 7 Ultimate running system. This is the first time the program has been out of its wrapping (ok, I am a little behind!). Since I recently purchased and loaded a full Revit Architecture 2013 package, I was attempting to use the AutoCAD program to supplement/add to my building model program(s).
What do I have to do to make AutoCAD 2007 work on my PC?
Solved by pendean. Go to Solution.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
My reply was not for you.. @Anonymous asked today to have a download link for AutoCAD 2017
Mark Lancaster
Ah ha! Your reply came through my email, appeared as though you were responding directly. I responded through the email...sorry.
Hello @Anonymous,
Thank you for your post, the operating system is considered unsupported for the product.
AutoCAD 2007 was not tested to run on Windows 7. This doesn't mean it will not work but most likely with all the OS updates & new component products, it will fail or eventually fail. Here is a link to review the system requirements.
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Do to security risks I will (and others should) not click on your provide links but under the Crack link, are you actually providing a method in how to crack the activation?
Mark Lancaster
