Installation & Licensing
Application start error
5 REPLIES 5
1422 Views, 5 Replies
Whenever I try to start Autodesk Inventor pro 2014, it says;
Inventor.exe - Application Error
The application was unable to start correctly (0xc0000142). Click OK to
close the application
I tried to uninstall and reinstall the product, but I keep getting the error. I even tried opening it in windows
diagnostic mode - still no use.
5 REPLIES 5
david.lau
Please check your video card and confirm that it is certified to run with your version of Inventor that you have installed on your computer.  If you have an Nvidia Geforce card on a laptop, you can try the following:
http://upandready.typepad.com/up_and_ready/2013/08/fatal-error-autocad-architecture-2014-2012-geforc...\
David Lau
in reply to: david.lau
Alright I fixed the problem, it was caused with an incompatability with Windows 8.1, all you have to do is install SP1 for Autodesk Inventor 2014 (I'm sure there is a service pack for 2013, too)
The SP1 download link for 2014: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019
Hey Najmos.sakib, Thank you very much for letting me know the solution. I've been searching around and got no real good answer until I stumbled upon this thread. It worked like a charm and I can now breath easier. I wish it didn't take me a day to figure out, but man am I glad your solution worked! Great job! Derek
Whenever I try to start Autodesk Inventor pro 2013, it says;
Application Error
david.lau
Administrator Productivity
