So I finally managed to buy the shape modeling for Rhino plug-In (see this Thread).
I have received the Autodesk email with Product key and serial number.
After starting Rhino the "trial version" screen pops up and I use the "activate..."-button to get to the next scren and fill in serial number and product key.
Everything seems to go fine and I instantly get another email from Autodesk with an activation code.
I am a little confused because the activation process seemed finished, so using the "about..."-window and the "product info" -button I get this window:
As you can see, the License Agreement button is greyed out, but there it is another "Activate" button!
Just when I press it, a small window appears for a couple of seconds (saying: "verifying license" or something like that), then it closes bringing me back to the unaltered "product info" window.
Instantly I get just another email from Autodesk with yet another activation code.
I am really confused.
The product works fine so far (no trial popup after starting Rhino anymore).
But is the plug-In activated/authenticated or whatever You like to call it?
Do I need to fill in any codes or am I fine as it is?
Where can I find the license agreement?
Any information that clears up these questions would be appreciated,
Norbert
the autodesk license agreements are here: http://usa.autodesk.com/adsk/servlet/index?id=10235425&siteID=123112#section3
your product is activated based off that it says standalone locked and license behavior: permanent
no need to do anything else
DarrenP
Hi Darren
That was what I was thinking too. But why do I receive another activation code by email then?
That seems quite confusing to me.
Anyway thanks for clearing things up.
By the way: there is no license agreement for the Shape Modeling Plug-in listed on that page You linked to.
Cheers, Norbert
