Installation & Licensing
ACADE deployment starts, doesn't finish
1 REPLY 1
robbm2k
298 Views, 1 Reply
We've used the same deployment shortcut on multiple machines without issue, as recently as a month ago. On a new machine, when the install link is opened, the progress bar comes up for initializing setup and installs MS Visual C++, and then it ends abruptly, with no error message or anything. Below is what the log file shows (i included the log of the last successful install). I also attached the full file. Anyone have any thoughts? Thanks in advance.
2012/11/19:09:09:29 install LDELL-1221 === Setup started on LDELL-1221 by install ===
2012/11/19:09:09:29 install LDELL-1221 Launch
2012/11/19:09:10:05 install LDELL-1221 Installing Autodesk® Design Review 2012: TRANSFORMS="\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\x86\en-us\Components\adr2012\SetupDesignReview2012-ACADE_2012.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/19:09:10:37 install LDELL-1221 Install Autodesk® Design Review 2012 Succeeded
2012/11/19:09:10:37 install LDELL-1221 Installing DirectX® Runtime: \\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/19:09:11:35 install LDELL-1221 Install DirectX® Runtime Succeeded
2012/11/19:09:11:35 install LDELL-1221 Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/19:09:12:06 install LDELL-1221 Install FaroSDK Succeeded
2012/11/19:09:12:06 install LDELL-1221 Installing Autodesk® Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/19:09:12:29 install LDELL-1221 Install Autodesk® Material Library 2012 Succeeded
2012/11/19:09:12:29 install LDELL-1221 Installing Autodesk® Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/19:09:13:07 install LDELL-1221 Install Autodesk® Material Library 2012 - Low Resolution Succeeded
2012/11/19:09:13:07 install LDELL-1221 Installing Autodesk® Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/19:09:13:28 install LDELL-1221 Install Autodesk® Content Service Succeeded
2012/11/19:09:13:28 install LDELL-1221 Installing AutoCAD® Electrical 2012: TRANSFORMS="\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\x64\en-us\acade\acad.mst;\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\x64\acade\acad-ACADE_2012.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\" INSTALLDIR="C:\Program Files\Autodesk\Acade 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/19:09:19:22 install LDELL-1221 Install AutoCAD® Electrical 2012 Succeeded
2012/11/19:09:19:24 install LDELL-1221 Installing AutoCAD Electrical 2012 Language Pack: TRANSFORMS="C:\Users\install\AppData\Local\Temp\_AI3929.tmp\_laA026.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\" INSTALLDIR="C:\Program Files\Autodesk\Acade 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/19:09:22:43 install LDELL-1221 Install AutoCAD Electrical 2012 Language Pack Succeeded
2012/11/19:09:22:46 install LDELL-1221 === Setup ended ===
2012/12/14:09:52:23 install LLENOVO-1351 === Setup started on LLENOVO-1351 by install ===
2012/12/14:09:52:23 install LLENOVO-1351 Launch
2012/12/14:09:52:51 install LLENOVO-1351 Installing Microsoft Visual C++ 2010 Redistributable (x86): \\sstor\software_images$\CAD\AutoDesk\AutoCAD\Electrical\2012x64\AdminImage\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\install\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/14:09:52:53 install LLENOVO-1351 Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/12/14:09:52:55 install LLENOVO-1351 === Setup ended ===
1 REPLY 1
pendean
in reply to: robbm2k
Search the autodesk firum or Google for your iasue while you wait, it seems you posted it to be C++ 2010 failed to install, result=1603 (read towards the bottom of your long post).
Administrator Productivity
