Installation & Licensing
Install AutoCAD LT® 2013 Failed Installation aborted, Result=1603
1 REPLY 1
SNA
Community Visitor
1772 Views, 1 Reply
In attempt to install the AutoCAD LT 2013 on a win xp 32 bit machine, the following error occured.  Please advise on how to resolve this?  The installation is done on local drive, and install without including autocad sp.
Following is the error log:
2012/12/14:11:28:15 JC VOSTRO400 === Setup started on VOSTRO400 by JC ===
2012/12/14:11:28:15 JC VOSTRO400 Launch
2012/12/14:11:28:22 JC VOSTRO400 PageOpen LaunchDialog
2012/12/14:11:28:26 JC VOSTRO400 PageOpen LicenseDialog
2012/12/14:11:28:29 JC VOSTRO400 PageOpen ProductInfoDialog
2012/12/14:11:28:35 JC VOSTRO400 PageOpen ProductSelectionDialog2
2012/12/14:11:28:51 JC VOSTRO400 PageOpen FullProgressDialog
2012/12/14:11:28:51 JC VOSTRO400 Installing DirectX Runtime: C:\Autodesk\AutoCADLT_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/14:11:29:16 JC VOSTRO400 Install DirectX Runtime Succeeded
2012/12/14:11:29:16 JC VOSTRO400 Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCADLT_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/14:11:29:49 JC VOSTRO400 Install Autodesk Material Library 2013 Succeeded
2012/12/14:11:29:49 JC VOSTRO400 Installing Autodesk Material Library 2013 - Low Resolution:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCADLT_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/14:11:30:26 JC VOSTRO400 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/12/14:11:30:26 JC VOSTRO400 Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCADLT_2013_English_Win_32bit\x86\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCADLT_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/14:11:30:49 JC VOSTRO400 Install Autodesk Content Service Succeeded
2012/12/14:11:30:49 JC VOSTRO400 Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCADLT_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/14:11:30:58 JC VOSTRO400 Install Autodesk Content Service Language Pack Succeeded
2012/12/14:11:30:58 JC VOSTRO400 Installing AutoCAD LT® 2013:  TRANSFORMS="C:\Autodesk\AutoCADLT_2013_English_Win_32bit\x86\en-us\acadlt\acadlt.mst;C:\DOCUME~1\JC\LOCALS~1\Temp\_AIDB.tmp\x86\acadlt\acadlt-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCADLT_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/14:11:34:34 JC VOSTRO400 Install AutoCAD LT® 2013 Failed Installation aborted, Result=1603
2012/12/14:11:34:48 JC VOSTRO400 Rollback Autodesk Content Service Language Pack Succeeded
2012/12/14:11:35:01 JC VOSTRO400 Rollback Autodesk Content Service Succeeded
2012/12/14:11:35:39 JC VOSTRO400 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/12/14:11:37:03 JC VOSTRO400 Rollback Autodesk Material Library 2013 Succeeded
2012/12/14:11:37:03 JC VOSTRO400 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
1 REPLY 1
pendean
in reply to: SNA
Search the Autodesk forums, or website, or through Google search for Error 1603 that is noted in the error message you posted and try all the suggestions while you wait.
Administrator Productivity
