Hello, my 3DS Max is failing to install. I've been trying to fix this issue for quite some time now and don't seem to be any closer. Looking through my %temp% file, I think my problem is here. It seems to be a permission error?
Property(S): SOURCEDIR = C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\x64\max\
Property(S): SourcedirProduct = {52B37EC7-D836-0409-0064-3C24BCED2010}
Property(S): MR_PORT_OK = 1
MSI (s) (10:4C) [20:56:56:224]: Note: 1: 1708
MSI (s) (10:4C) [20:56:56:224]: Note: 1: 2205 2: 3: Error
MSI (s) (10:4C) [20:56:56:224]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1708
MSI (s) (10:4C) [20:56:56:224]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (10:4C) [20:56:56:224]: Product: Autodesk 3ds Max 2014 -- Installation failed.
Is this my problem, and how can i fix it? My error log gives me a generic 1603 error. Thanks for any help.
Rename C:\Autodesk to C:\Autodesk2.
Download Max using a browser download via our Virtual Agent (#3) noted here:
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
Thanks for the reply.
I have tried downloading it with all three options and two of them fail with the same error. The download manager option had an error and failed the download completely.
Nope didn't work :(. Gets to 7/12 left and fails on 3ds max 2014 and starts rolling back. Just installing the .exe for 3ds max only gives me an error "Service 'mental ray satellite for Autodesk 3dsmax 2014 64bit failed to start"
If you have an older version of Max installed, uninstall Backburner, reboot and try the install again.
