Hello every one.
i have a laptop.
using maya 2015 on windows.
but now i want to use it on fedora.
when i run maya without optirun, then create a Polygon and hit 3 for high quality,
i get this warning:
Warning: OpenSubdiv shaders are not supported on this graphics card. Using fallback render.
after that when i click on the Polygon, Maya crashes with this message:
Fatal Error. Attempting to save in /usr/tmp/%usr%.20141107.2000.ma Writing crash report in /usr/tmp/%usr%.20141107.2000.crash
so i thought the problem is my graphic.
then i run it with Optirun to use my Nvidia graphic, and after running Maya, it immediately crashed, with that exact message!
nobody knows why is that, and because of that i asked here.
so please help me.
thank you all
and sry for my poor eng
finally find the solution:
do NOT use Maya 2015, instead install one on the older one
i installed Maya 2014 and it works like a charm!
