Message 1 of 1
Create Fly-through Buildings
- Mute
- Permalink
- Report
- Import your Revit File into InfraWorks 360
- Select the Local road of the Road Design Module for Infraworks 360
- Select "Null" road as style
- Sketch the fly path going through the building
- Select Storyboard
- Select Create from Design Road animation
- Select the path you designed
- Viola' you can now play the storyboard and go through your building
- Adjust using the grips to go make sure you go through doors
- A tip: Create your paths on a different proposals and then play the storyboard on your final model! This way you can keep all your paths witouth the need to delete them!
