Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Some question about MapGuide Enterprise 2011
2 REPLIES 2
428 Views, 2 Replies
Dear All:
This my first time to use MapGuide Enterprise 2011.
I have some question of MapGuide Enterprise 2011
1. It has ony one site hhen I use Autodesk MapGuide Studio.
  Is it possible to run multiple site on single MapGuide Enterprise Server?
  I have 2 web site called SiteA and SiteB.
  The site use different map and the SiteA can't view SiteB's map.
  So I want create 2 site in MapGuide Studio.
  Can I do it?
2. Can I export MapGuide Studio' configuration and Import the configuration into another Server (like the MWF file in MapGuide 6.5) ?
2 REPLIES 2
As far as your 1. goes you can just create a different weblayout for each "site". Each layout has it's own specific URL so you can just direct your users to access the appropriate one.
I'm unsure of your 2. as I've never used Mapguide 6.5
Daniel.Du
For your second question.
Yes, it is possible to export/import your confuration from on server to another. You can pack/load *.mgp file in MapAdmin
http://<yourhost>/MapGuide2011/MapAdmin/Login.php   --->  Manage Packages from left.
Daniel Du
Developer Technical Services
Autodesk Developer Network
