Hello, we fix the label for the pipe in our Topobase application. These labels are a position define by the system on the top and the left position.
Before the new version, we can choose with the label mask the exact position of the label and every things was ok. But with the new version the mask is changed and we don't find the same possibility for the placement. Do you have a solution? Thanks in advance for your help
what was your old version, what is the new version and to whioch dialog/setting are you refering?
Label definition in Map-Administrator?
Rob
Do you speak french?
You will found in attach the copy from the old and new mask we use(d).
The old version was Map Guide 2010 and the new is Autodesk Infrastructure Studio 2014 version 2.5.1.7601
Hi Paul,
we use 2013 and the dialog box looks similar to 2014 but without the "Avancees" section. Isn't this the part where you could set the horizontal and vertical alignment?
Rob
Hi, Autodesk support give us the answer to our problem, the way to follow:
So we have the solution and can close the forum support.
Thanks again for your collaboration
Paul
