Project geometry as construction
Instead of having Fusion automatically project all the geometry when creating a sketch, I'd like the ability to choose what geometry I would like to project. And before I project it, have the optoin to project the geometry as construction geometry instead of having to change that property after it is projeted.
7 Comments
HughesTooling
I think at the moment it would be better if it defaulted to construction, I'd spend less time changing it back than I do now. Smiley Very HappyAlso when you select edges for dimensions and constrains they should default to construction.
Mark.
brianrepp
Status changed to: Gathering Support
It doesn't matter which it defaults to, just allow it to project as the "opposite of default" with a modifier key.
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
pavmed
pavmed
Finally! They've fixed that   https://youtu.be/JqWqPsgrDwA  ))
