I need to be able to engrave a line (multiple open profile - sketch) to our sheet metal profile.
An additional feature could be added, where we could project a sketch (line, open profile) onto a folded sheetmetal part, and this then transferes to the flat pattern. The feature Emboss could be improved by adding a feature called [Engrave from line] right next to [Emboss from face] [Engrave from face].
The feature must NOT remove material and thereby alternate the physical properties. The mass has to stay the same before and after this feature is applied [Engrave from line]. The depth has to be grayed out when using this feature.
Hope this idea will be well received, and that we (at GEA Scan Vibro) is not the only ones having this issue (We had a similar feature in Solid Edge, which is our old CAD system).
