Hi!
Is anyone else having this issue? I am running build 245, 8.0.0.20782, Release 2021.1, Date 07/21/2020. The Flow operation will not generate a tool path. I sent the model to my technical support and it worked just fine on their older version. I've attached a simple example. It will not generate a tool path for me on this part.
Thank you for any insight!
Hi @jstrecker,
I don't changed anything and recalculate the Operation. All works fine!
Inventor CAM Ultimate: 8.1.2.21785
Your operation has this error: "The chosen operation is not compatible with the selected setup."
Looks kinda weird. Have you tried to make a complete new setup and operation?
@jstrecker Did the information provided by @FTKnur answer your question? If so, would you please use Accept Solution so that others may find this in the future? Thank you very much!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
