we have in the last time often a Problem with our NC-Code. Our machines brings the error: tool radius too large. (Heidenhain)
I looked in the NC-Code and noticed that there are sometimes issues with the circle centers.
Simply a 2D-Contour with 4 bores.
Bore 1 has 3 CCs
Bore 2 has 4 CCs
Bore 3 has 2 CCs
Bore 4 has 1 CC - all other should look like this!
Sometimes the CCs are the same but when you look at the Bore 2 you see that there are different coordinates.
I tested it with other Posts from Siemens and there is the same Problem.
Have someone the same problems?
Can someone test the file with there own Post?
It seems like it is off by 0.0001mm. Not sure if that really is an issue.
I can't think of a way to would cause trouble with the radius compensation.
What exact line does it error on?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
In this case it is just 0,0001 because that is a modell made by myself. But last week i get a STEP and there is a Bore with Ø28,5mm.
There i have a 0,012mm CC difference. The problem i have is not to milling the bore complete but when i want to add a horizontal lead-in radius
the machine get the error. I think that this is the reason for the error. The original bore CC is not at the correct point. The error emerges just by lead-in or lead-out radius.
I never can set the Starting point in the radius in a slot hole. There I get by 99% an error.
But I dont know why there are anyway different CCs.
Because of tolerances, you get different Centerpoints.
But those are most probably 1/100 of the tolerance you set in the operation. So not really something that is an issue.
Is you set the tolerance in the operation to a smaller number you should get less deviation.
But since these lines don't cause the actual error I wouldn't go looking for that as the problem.
Let's try and find out why it doesn't work when you enable the horizontal lead-in radius.
What tool and settings make the machine error?
Laurens Wijnschenk
3DTechDraw
René for Legend.
OK... now it's really crazy.
I've tested the same programm on a other computer. There is a complete other NC-Code with the same post processor.
I checked the versions -> both the same (Inventor HSM Premium Build 5.3.1.63)
The other nc-code works fine, so I reinstalled HSM.
And now its the same NC-Code and it works better (not so extremely offsets (0,012)).
Now it works much better for me - however this happened. I still have more CCs but i don't care about that.
I hope that is solved with the reinstall.
Thanks for your help 🙂
