I opened Fusion 360 and it said that it couldn't go online. I tried a couple of things (restarting the router, restarting the pc) but without success.
After that, I decided to reinstall it. I have attached a screenshot with the app after the reinstall, all being white, without any options.
I have tried after the reinstall:
- 4x reinstall
- 2x repair
- 1x uninstall and delete the files and then install again
- run as administrator afer each reinstall
- PC restart after each reinstall
Did this occur to anyone else?
Good day @radupersoiu,
have you tried connecting on a different network of installing Fusion 360 on another PC?
Hi Pieter,
I am working on my PC, and I do not have any other access to internet despite my ethernet cable.
Could you please detail how installing it on another device would perhaps solve this?
Radu Persoiu
The request was to see if your network wasn't allowing Fusion to connect to the server and verify your license.
Have you by any chance seen this forum posting with a similar issue?
I did see it.
I have installed it on a laptop using the same network as my PC.
Everything seems to be fine on the laptop, the app can be used.
That is strange,
Seems that this issue has to do with your PC.
Have you tried installing and running Fusion 360 on another user account on the same PC?
Thank you for the feedback.
Seems that your user account is corrupted.
I'd recommend moving over to a new one. not ideal but better then formatting 😁
Thank you for the help Pieter.
I will try a couple of more things just to make sure I don't have any other solutions and if it will work, I will post it here.
@radupersoiu One another thing to try before you create a new user ID could be, please go to your registry and delete HKEY_CURRENT_USER\SOFTWARE\Autodesk\Fusion360\DP. See if this helps?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Hi Rajkumar,
The only file in here is '(Default)'. I have deleted it but it hasn't fixed the issue
Ok. Thanks for trying. Recently I know there was one issue where deleting the rekey fixed it and hence wanted to see if it was the same issue. Looks like it is not connected.
Autodesk Fusion
Join Fusion Insider
I couldn't solve this problem for a month, but this solution with the registry helped.
