Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Autonumber, restarting at 1
4 REPLIES 4
638 Views, 4 Replies
I've been working on a test site for our company and I'm just about ready to go live with it.
After I clear out all the test entries in the workspace is it possible to restart the Autonumber at 001?
Mike
4 REPLIES 4
bastien.mazeran
Hi Mike,
I suspect you used the purge command in workspace manager to remove your test items. If I am correct, the AUTONUMBER field counter does not currently get reset as part of purge command. You probably want to consider cloning the workspace if resetting your AUTONUMBER field to 1 is critical.
Bastien Mazeran
Technical Support Specialist
Nope, doesn't reset.
Mike
bastien.mazeran
Hi Mike,
You will need to clone the workspace to reset the counter back to 1. Further to this, please note that the issue with purge command not allowing to reset the auto number counter is on the roadmap.
Bastien Mazeran
bastien.mazeran
Hello Mike,
Please note that with the new release that was deployed over the week-end the autonumber will restart at 1 after purging the workspace.
Bastien Mazeran
