I have an assembly. There is a part that I cannot move because it is defined by joints. Using the same assembly in a new version with new parts the defined part now moves when I apply joints to other parts. This should not be happening. Any help is much appreciated.
Thank you
Solved by TrippyLighting. Go to Solution.
In your base file, at least one Component is Grounded.
When you insert that file into a larger assembly file, the Joints it had are maintained, but the Grounded status is not. This is because it is assumed that you will want to Joint (and move into position) your inserted base file into a new position within the larger assembly.
If you don't want it to move, you will have to reestablish the Grounded status within the inserted version of it.
Please tell the best way to send you the model. I cannot post it to the general public. If the only way to get help is to share it then I can only share it with you.
Now having had a chance to look at the design, I don't think you understand at all how to properly assemble components in Fusion 360. The joints you use are all wrong, starting with the first one. You don't need there individual joints to assemble these 2 components, you need one rigid joint.
The joints in Fusions 360 are NOT like geometric mates in other CAD software.
There is also no need to use the move tool and move a body away from its origin to re-orient it before assembling.
And that's just the first small section of your timeline. The 2 move commands are not needed. The three joints can be replaced with a single rigid joint.
Here's another no-no
You have a body that should be in its own component located in an assembly that also hosts one or more other components at the same structural level.
I wonder how you want to move forward from here. You cannot share the design, so we cannot post it here and have other people also benefit from the learning content, but you clearly need some help.
In a feeble attempt of shameless self advertising I would like to mention that I do offer professional 1-on-1 Fusion 360 support and private tutoring for Fusion 360. Please let me know if that interests you.
