Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Hub Configuration failed
1 REPLY 1
241 Views, 1 Reply
Not sure what the problem is, says contact forum.....
1 REPLY 1
herzinj
Hi aliasbilly,
It looks like when people have encountered this in the past the issue has been resolved by one of the following:
1. uninstall/reinstalling the software
2. making sure no antivirus software is running
3. ensuring good connectivity to the internt
If none of these work, you could try creating a new account and see if this helps with the issue.  If you continue to have have trouble with this, could you please send me your email address in a private message or to james.herzing@autodesk.com and we can look into what the problem may be?
James
https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png
