Concentric Dimension
4 REPLIES 4
kellings
700 Views, 4 Replies
I couldn't seem to add a dimension between 2 circles. I wanted to define a wall thickness. See attached image for what I was trying to do. I wasn't able to add the .25" dim in my Fusion sketch.
Is this a limitation or am I doing it wrong?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
4 REPLIES 4
schneik-adsk
in reply to: kellings
This is a dimension type Fusion 360 can not create today. You can fake it. Place two points one on each circle. Make these points same Hor/Vert. Then dimension between the points.
Kevin Schneider
kellings
in reply to: schneik-adsk
Would you like an enhancement request filed for this, or is this just on the automatic to do list?
Kevin Ellingson
schneik-adsk
It's on the to do list.
Kevin Schneider
rdubard
This is on the 'to do' list since 2013?
As an instructor who needs to distribute engineering drawings for students to learn how to model to reflect design intent, I find the lack of this feature really frustrating, and frankly, it seem lazy to me that Autodesk has not yet addressed this very basic drafting method.
(And yes, I KNOW you can put two points and dimension between them, but that is really clunky)
Do better.
