I am currently designing a lightsaber hilt in Fusion. I noticed this mesh (attached below) in my design. I've turned off all objects, sketches, planes and anything else it could be. I have deactivated the master component, and it still wont disappear. The mesh cannot be selected at all either. After scouring the design history I had no luck in finding where this came from. My best guess is that they are artifacts from when the object was extruded? Regardless please help to figure out how to remove these meshes from my design.
Hi @Anonymous ,
Please attach prior designs that you have already completed in Fusion 360.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souzaHi @Anonymous ,
The bodies are you have highlighted in the first post are hidden and will show preview when you click on top browser node on the hidden body.
If you dont want to see them, try to find the hidden body, Right click and remove.
Sujay D'souza
