No. You don't want to use ASCII. That is what corrupted them. Those of us
who use old school ftp issue a bin command as in
ftp myserver
bin
put my.dwf
The FTP Voyager tool probably does not know what type of file DWF is and is
defaulting to ASCII. If you upload them as JPG and then rename them on the
FTP site to DWF, maybe you can fake it out.
wrote in message news:5861354@discussion.autodesk.com...
Can you view these files correctly from your local disk?
NO. I just downloaded, using FTP, back to local disk and Design Review
reports corrupt!!! I see what you mean.
When you transferred these files to your server did you use ftp?
Yes
If so did you do a binary transfer?
I am not 100% positive as I just checked FTP Voyager settings and see that
they are "Automatic"
If you can get the files on your web server corrected your should be up and
running.
Thanks Ben. I will look into this corruption issue further.
Is ASCII the preferred method of transfer?
