FM (Read Only)
Body deformation
2 REPLIES 2
1785 Views, 2 Replies
Body deformation
Hi,I build the bones for my character,but when I move the bones the body deformates,how to eliminate this annoying thing?
Thanks.
2 REPLIES 2
Mistress0fTheDorkness
I'm not sure what program you're talking about... I'm assuming you'll need to ask your question in one of the following locations, since that isn't something people here would be experienced with:
http://forums.augi.com/forumdisplay.php?f=769
http://forums.augi.com/forumdisplay.php?f=300
http://area.autodesk.com/forum/autodesk-maya/
http://area.autodesk.com/forum/autodesk-3ds-max/
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
I use the biped which I find simpler than bone fragments and use the Epidermis modifier after to management the way the body system gets altered. There are good tutorials in the help.
