FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
Determine where materials change?
5 REPLIES 5
162 Views, 5 Replies
Hello again, people 🙂
I'm setting the mapping mode to eBY_POLYGON_VERTEX on all my elements, then optimizing later. However, for batch drawing in graphics rendering, how might I find out on which vertex do the materials change?
Example:
There's three materials on a mesh. After converting the mapping mode to eBY_POLYGON_VERTEX, the first material uses vertices 0-6, the second uses 7-12, and the third uses 13-23. Where would I find these values?
Many thanks! You have all been very helpful!
-Thomas
5 REPLIES 5
Bump.
These are also called Material Groups in other formats, such as ASE. Does anyone know how to get a hold of these?
I seem to have found what FBX uses instead of "material indices," which makes more sense for the format but is a bit more challenging to process.
If there are multiple materials in the same FBX file, they're stored in different layers. This is seen in the "Layers" example. Each different material + corresponding UVs are presented in each different layer, whilst all the geometry/normals/etc are present in the zeroth layer.
I'm using 3ds Max to create these models. You can set multiple materials for the same object via material channels for each face. How do you retrieve these faces in FBX?
-Tom
Look at DisplayMesh.cxx in the FBX SDK ImportScene example.
function DisplayMaterialMapping
leMat->GetIndexArray().GetAt(i)
returns each face with that material applied
Perfect, this is exactly what I was looking for! Thanks again, Doug. Merry Christmas to you.
Look at DisplayMaterialConnections, also
There is a special case: KFbxLayerElement::eALL_SAME
Merry Christmas to you, too.
