Ecotect Analysis Forum (Read Only)
gbxml error in Ecotect 2011 while importing from Revit 2013
11 REPLIES 11
Message 1 of 12
4972 Views, 11 Replies
When I want to import a gbXML file in ECOTECT 2011 - (created in REVIT 2013), I get this message:
"WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly"
And it does import nothing (0 spaces, 0 surfaces, 0 ...)
What's the problem? How can this be solved?
Thank you
11 REPLIES 11
Message 2 of 12
I have the same probelm....
anyone knows a solution for this problem??
please HELP me....
Message 3 of 12
Stephanusc
Same problem and the info required is urgent!
Any solutions? Anyone...
Message 4 of 12
I have the exact same problem. It is something to do with Revit 2013 as I never had any problems importing from Revit 2012.
Message 5 of 12
jopetit
I have the same problem, with revit 2013.
With 2011 it works
I hope some answer from somebody
thanks
Message 6 of 12
in reply to: jopetit
Message 7 of 12
Message 8 of 12
This is still not working for me can I get a step by step instruction please? What do I do once I open the gbXML in notepad onwards? I still receive an error message in ecotect.
Thanks!
Message 9 of 12
Thanx a ton mate.. Cheers!!
Message 10 of 12
Hi I am facing the same problem (IFC Warning while importing "revit 13 exported gbXML file" to  Ecotect)...Plz help
Message 11 of 12
Pennetier1
All,
Indeed, Revit 2013 started using a different gbxml file format that can no longer be read by Ecotect.
Another alternative to manually modifying the gbxml file is to use this online converter:
http://www.fileformat.info/convert/text/utf2utf.htm
All that needs to be done is upload the gbxml file from Revit 2013 and click the Convert button.
The converted gbxml file should now be readable by Ecotect.
It has worked for me consistently.
I hope it helps some of you.
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Cheers,
Olivier A. PENNETIER
SYMPHYSIS
www.symphysis.net
Message 12 of 12
cmompean
It works perfectly, Thanksss!!!! By the way you need to download notepad ++
