Ecotect Analysis Forum (Read Only)
DOE2 Simulation error, how can I track down the elements causing the issue
1 REPLY 1
scott.chatterton
1150 Views, 1 Reply
I'm trying to run a gbXML file but am receiving the following error:
"Two Vertices are identical". See attached image.
Trying to identify these two verticies so I can delete them...but cant track them down. I have stripped out as much as I can out of the model... any sugestions?
The gbXML data dosent include the Revit ID?
The Revit Jedi
1 REPLY 1
A work around for the DOE-2 error message I discovered was to copy clip the model into another new "Blank" project. I had to recreate the spaces in the new project but I could sucessfully run the newly created gbXML file in GBS.
Sc
The Revit Jedi
