I'm trying exactly what you said and that doesn't work me.
It is the same procedure for a text in the dynamic block?
The only way I found to have my text horizontal.
I made an angular dimension removing lines of dimensions.
But it's good only for 1 side of a circle on the other side I have to do another angular dim.
And play with visibility.
Post your Block please.
It is likely a piece of something like the Chaining that is missing.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
What Text do you want to keep Horizontal and what Rotation Action is it tied to?
I don't know what I did wrong the first time.
But when I try again it works fine.
So thanks Charles for trying helping me.
Hey,
I have a similar problem. I have a block with an attribute that must be mirrored, and the text should stay readable. When I lock the position of the attribute it won't mirror. And adding a point parameter doesn't work as well.
Thanks for helping!
Frank
Hi, you have to explain better what you want to do, your block contains geometry but 0 dynamic objects.
Using a chained point parameter with a move action assigned to the attribute and then flip the point parameter but not the text works for a fact.
If it doesn't work for you, try Attsync on your attribute after block has been saved.
Usually when you save a block that is already referenced in a drawing an Attsync command is required for the attributes to update aswell...
Problem solved:
