Dynamic Scale Bar Questions
doni49
Mentor Mentor
doni49
Hi all.  I'm working with C3D 2014.  I am trying to convert our standard scale bar for use as a dynamic one that's tied to the viewport.  But it's proving to be really difficult.  I've got it so that it shows the correct numbers but I need to add text (see the image below).
But because these numbers have to be in a specially named attribute, I'm at a loss as to HOW I'm going to make this happen.  I thought about just making them another text element right next to the attributes.  But that could result in the text being too far right (lots of space between) or too far left (text on top of the attribute).
Also -- when placing this bar, I have to manually set the units to FEET and turn on the checkbox "Adjust divisions on zoom".  Is there anyway to set these to be on by default for this scalebar?
I've attached my test file.
TIA!
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Libbya
How are you tying it to the viewport?
doni49
When I first switch to a layout tab, the "Layout Tools" ribbon tab also activates (see the image below).  I select "Scale Bar" and it eventually prompts me to pick my vport.
Don Ireland
Libbya
I'm on AutoCAD Architecture 2015 and it doesn't seem to give the scale bar option.  I'm not sure how it references the block and applies the info, so I'm afraid I can't really help.
Have you seen this article on linking dynamic blocks to viewports?
ojuris
hi!
method in that article can't be used in attributes -> blocks
this fields You can write in texts
see attached file
Regards
Juris
