Hey,
I'm trying to make a dynamic block that moves to lines in opposite directions with one grip. currently I'm just using a seperate move action for the other line i'm trying to move. I've attached the block to further drive the point home as I'm having a hard time articulating my thoughts.
Solved by jarredmonday. Go to Solution.
I'm assuming this is what you're looking to do? What is the application for the block?
Would you be able to explain how you got the ends of the brackets to move without them changing size. I'm just curious for future reference
Click on Stretch3 and in the Properties window look at the Distance multiplier.
In this case setting it to a negative causes the end to move in the opposite direction.
This is one of several ways this can be achieved.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Saved in an earlier version.
