Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Okay I finally got around to doing up a toilet, sink and grab bar. I know, simple stuff. The toilet and sink use visibility states to show four variations. The grab bar uses a simple stretch to choose between 36" and 42". All have a centered basepoint and alignment parameter, but I have added grips so they can be dragged into final position. For example, the grips for the water closet are 18" from the insertion point, so it can be inserted against a wall and then dragged to 18" from the corner. The ADA lav's grips are 15" from the insertion point. And the grab bar's grips move from 3" from the centers of the ends of the bar (36" version) to 12" for the 42" version. Use them if you like them...
Btw, notice I shortened my designation to DBk (got that off of a really old post), to differentiate from database or dialog box or whatever. I also have a hatch pattern for batt insulation if anyone's interested...
An interesting use of Polar Parameters from 12/20/2010
TEST-2 in the First Vis State is the solution
Thanks for the Grab Bar
The Artist Formerly Known as Modman says you're welcome 🙂
Mucking about with a few things on these still, trying to make them as idiot proof as possible. The one on the right uses fields so needs to be regen'd after stretching.
Yanno, it's kinda a shame they can't combine the number of posts I made as Modman, with my current ones -- that would probably make me a Mage or a Wizard or something, yesno? 😛
You'll get a Kudos for that but you are still an apprentice my young Padawan...
