I have read through all the forum posts regarding Dynamic block attributes not updating, but I have not seen an answer to my question.
I use attext in Autocad LT 2014 to extract data from attributes in the drawing. The block has 7 attributes, and 3 of 7 are constants. If I insert blocks in the drawing and run the attext command, the data extracts without an issue. However, if I make a change to any blocks already inserted into the drawing, then all the constant attribute values disappear in the attext report.
The attached PDF expains the problem. I have also included the block and attext template file.
Does anyone know why the constant attributes disappear after a block edit?
After you change one and the ATTEXT no longer works run LIST and see if the Block is an anonymous name now and not the actual Block name.
SWAG.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I ran list command before and after the block edit. Before the edit, the block only had a block name. After the edit it still had the proper block name, but it also had an anonymouse name. What does this mean?
I am wondering if the anonymous name is what is crashing your extraction file and I don't know a solution right off for that.
