I am not sure if you want your blocks to be dynamic or not.
At the moment you dont have 'dynamic' block.
I guess your blocks are columns.
If you want to change the color of a particular block, enter BE at the
command line.
This will display a dialog with the block names currently defined in your
current drawing.
Select the block you want to edit.
This will open the block in the Block Editor.
Make any changes you want.....for example change the color of the solid
hatch.
Save the block defenition changes....see the button at left hand side of top
toolbar.
This will update all the instances of the block in your current drawing.
I noticed that the hatch pattern applied to your C18x42 block was duplicated
abour 3 or 4 times.
If you want this block to show different hatch colors, consider adding
visibility parameters
for say showing the block with color 30 and color 65 (or whatever)
You can then have the block display different as you want.
See attached sample
Leo
wrote in message news:5139691@discussion.autodesk.com...
Like the attached file. If I wanted to change the hatch patterns to color
#30 orange. How would I go about doing this?
What terms would define this change?
I keep reading other posts but I'm not sure what terminology describes the
block type nor how to change this in a specific drawing without affecting
other drawings.
