Dynamic Blocks Forum
copy drawing
8 REPLIES 8
Message 1 of 9
859 Views, 8 Replies
copy drawing
copy a drawing from autocad 2013 to autocad200
8 REPLIES 8
Message 2 of 9
Do a SAVEAS and under the File Name edit box in the Files of type: choose "Autocad 2000/LT2000"
Message 3 of 9
For some reason it won't let me pull a saveas box
Message 4 of 9
You can type SAVEAS right at the command line, Also clicking on the big A in the upper left will give access to Save As >
Paul S Christianson
Design Drafter II
4360 112th St.
Urbandale, IA 50322
Office: (515) 299-6346
Email: paul.christianson@hussmann.com
Website: www.hussmann.com
[cid:image001.jpg@01CC2A95.964E9D90]
The information contained in this message is privileged and intended only for the recipients named. If the reader is not a representative of the intended recipient, any review, dissemination or copying of this message or the information it contains is prohibited. If you have received this message in error, please immediately notify the sender, and delete the original message and attachments.
Message 5 of 9
You can type SAVEAS right at the command line, Also clicking on the big A in the upper left will give access to Save As > or is the problem you click on Save As and nothing opens?
Message 6 of 9
That what it is . Nothing opens
Message 7 of 9
AcadAdamLT
Use command "+saveas"
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Message 8 of 9
hwalker
Does no dialog box pop up at all? If you look at the command line is there a load of information there after the word save as?
If there is do the following
Press Escape a couple of times to get rid of it
Now type FILEDIA it will show <0> Just press 1 and then enter
Now when you do SAVEAS a dialog box will pop up.
Howard Walker
Left Handed and Proud
Message 9 of 9
dmfrazier
Here's a handy hint to keep in your back pocket (or up your sleeve, or behind your ear...): when FILEDIA is 0 (turned off, whatever the reason may be), and you execute any command that would "normally" pop up a file select/browse dialog window, typing a tilde character (~, located at the upper left of the keyboard), followed by Enter, will bring up the file select/browse dialog window so you can finish out the command in the comfy way you prefer.  Then you can turn FILEDIA back on later (as described in an earlier post), if you still feel you need it.
”Boost
”Tips
”Services
