Some of the people in our office use Trueview but are annoyed that they have to pick an object snap choice each time they want another point. Does trueview have a way to set default choices you want it to use for grabbing points, like autocad has?
Solved by mnorona. Go to Solution.
Solved by john.vellek. Go to Solution.
HI @sepower,
What kind of things are they trying to do that require this? When I use the measure command for instance, my cursor automatically finds an endpoint or intersection snap if I hover over the location. It confirms the point by displaying the snap that it is connecting to.
Are they doing something differently?
Hi Jeff,
So it isn't the snap but the actual command. Have him hit the space bar as this will repeat the last command.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
Hi sepower,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
We have the exact same issue and would like a further developed answer or solution to it.
The further extent of the problem is that you might need Nearest point first and then also Perpendicular or other snaps in a sequence, and DTV seems unable to remember several snap settings when repeating the command.
Also you need to redo the choices if you have used any other function between measurements.
With a lot of measurements to do this becomes "annoying" exactly as the original question so properly called it. In practical fact some 200% more unneccessary clicks and moving the pointer away from your area of operation.
We can't see the reason why snap preferences cannot be kept in a combination of your choosing like in regular Autocad and we wish to learn a way to set lasting defaults, or in case it is not possible, to make this a feature request for updates or future versions of DWG Truevuew.
Kindly
Jim Persson-Melin
CAD/BIM Consultant / Application Support
AEC AB - Advanced Engineering and Computation
Göteborg - Sweden
Hi @Jim_Melin,
Thanks for the input. I agree that additional feature enhancements would be a great addition to the product.
You might consider using A360 online for viewing the drawings. I has much smarter snaps in my opinion.
No @proyectosDDNRQ . You said "Press the [F9] key" Well, [F9] toggles "SNAP" on off, which is *NOT* the same as "OSNAP"
So, [F9] is NOT the solution at all.
Also, the issue is also that DTV does not rememeber chages in the snap-settings. You have to redo them repeatedly if you want something else than the default snap priorities.
Found someone, somewhere today who posted a solution to setting Running Osnaps in TrueView: 1-Begin the measure command. 2-at "first point" prompt, type: 'dsettings (apostrophe, dsettings). 3-the familiar dialog box will appear, select desired Running Osnaps (other settings also available). 4-Osnaps now active, continue with selecting 2nd point. These Osnap settings appear to remain in force for subsequent commands. Hope this helps! (but i cannot take credit, other than finding this by another). Enjoy!
... 2-at "first point" prompt, type: 'dsettings (apostrophe, dsettings). 3- ..
a) For heaven's sake! Is this the only way to invoke the settings command?
b) Works for me, thanks. (But improvement of a) would be better ..)
