DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Is there a trick to get xref's to show up?
2 REPLIES 2
LisaDrago
444 Views, 2 Replies
Hello - I have a client that is using TrueView. He has xreferenced files that are not showing up when he opens a file automatically. Is there a way to make this happen? Or does this have to be one manually to every file?
Does it have to do with the pathing? They are all set to a relative path.
Thank you for your assistance!
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
2 REPLIES 2
pendean
in reply to: LisaDrago
Yes, it's all about pathing: Unless his file structure is exactly like yours, you are always better off shipping files with no paths and all in one folder for someone else to look at your files.
LisaDrago
in reply to: pendean
We have tried no path - and this still didn't work. We are not sure what to do at this point.
Thanks for your help.
LD
