DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
File plot blank in TrueView but works in AutoCAD.
1 REPLY 1
1498 Views, 1 Reply
Hi guys,
I have some users who need to print dxf files (to paper and pdf). I installed DWG TrueView 2013 for them but whatever I tried, it always printed a blank sheet of paper.
So I decided to try with AutoCAD LT 2014. I opened the same file on the same computer and used the default plotting settings in AutoCAD and it worked right away. So I decided to apply the same configuration to TrueView's plotter but I still got the blank sheet of paper.
Anybody knows why this happens and how it can be fixed? On the same computer unser the same user with the same file and the same plotter configuration, it prints under AutoCAD but not under TrueView.
1 REPLY 1
pendean
Seems to work fine here: you might want to double-check the plot parameters, a DXF file has none by default.
