DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG TrueView 2013, 2014 error to make preview or to print
3 REPLIES 3
1299 Views, 3 Replies
Then i try to send print task (or make preview) in DWG TrueView 2013, 2014,  i take  "FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at e2561fe6h"
It be, then a use real prtinters such as HP5200, HP3525 (they configurade by HP uneviersal driver), but one of my printers work correct it's HP 1300 (it dosnt use HP uneversal driver).  Then a use DVG to PDF - print task (or make preview) work good.
I use Windows 7 Professional SP1 32bit or 64bit
Would you help me?
3 REPLIES 3
Charles_Shade
Welcome to the Autodesk Forums!
So you can get a print to one of the HP Printers (1300) and DWG to PDF will complete a print for you.
The other two printers will not work. You suspect the HP Universal Driver.
Are these two printers WIndows installed printers or are you trying to use a PC3 file when printing from DTV?
in reply to: Charles_Shade
 These two printers WIndows installed printers.
Charles_Shade
Can you roll back the driver or change the driver to the one that works on the other printer?
The Print and Plot Forum can be found here:
http://forums.autodesk.com/t5/Printing-and-Plotting/bd-p/30
There might be something there that pertains to DTV; if so, please link it nack here.
